How hard to go backwards?
YakkoWarner
Central Texas
Wolf
R2500 Suburban
My 1989 Suburban has the high-low beam switch mounted at the base of the column with the actuator rod going up to the turn signal/wiper/cruise multifunction lever. The rod does not seem to be connected to anything at the upper end anymore, I suspect the plastic has probably broken. The switch works just fine if you reach up there with your finger and press it, so I know there is no wiring failure.
I am wondering how difficult it would be to go back to a floor mounted button for the high-low beam function because frankly the thought of disassembling the column gives me nightmares. Has anyone does this?
Edelbrock
Earth
Grumba
K5 Blazer
I would assume that a floor mounted switch would be easy to install. Probably get one on Amazon cheap enough. The trick would be accessing the wires in the steering column. Maybe there is a wiring diagram on this site somewhere, so that you could take the wires from under the dash or something.
Strick
Dunn, NC
Harold
C20 Crew
The floor switch will plug directly into the column harness. You can make you a jumper lead to floor or dash mount the switch.
Strick
Dunn, NC
Harold
C20 Crew
Industry should quit with column dimmers because idiots keep getting their feet stuck in the steering wheel! I know, should've posted in the funny stuff...
HS
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Fortunately the wires don't go up the column, only the actuator rod - the switch itself is actually under the dash, pretty easily accessible.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Thats handy to know - extending wires isn't that hard. What year did GM go away from using the floor switch? If I know what was the last year for the floor switch I can just buy the part for that model year.
75-83 standard ignition ds72 or ds72t
Perfect! Once I get it back from the flexplate replacement I'll grab one of those and see what can be worked up. Thanks!!!!
Dammit man! Did you post up that you needed to change a flexplate? If so I didn't see it. Not a hard job,don't even have to really pull the transmission. Replace 2 of the bellhousing bolts with starter bolts,you can slide the transmission back on them far enough to change the flex plate. Yes it is more involved than that. Only posting this so next person will ask can you change the flexplate without pulling the transmission,can you change a flexplate with the transmission in the car etc. will get a hit in search. You are still doing the majority of a transmission R+R but still simple and just sliding the transmission back.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Yeah it was a whole separate posting about having the teeth chewed up - having to change starters in the car park at work, etc...and being on a 7 day a week work schedule for the past 3 months meant no time to mess with it.
FenderBanger
