Lights
kr155
usa
kamran
k20
I’m having trouble with my lights. The dome light,gauge cluster lights and one marker light works. I have power to the headlights and cab lights but no light. I’ve tried aftermarket led and original lights and still nothing.
Edelbrock
Earth
Grumba
K5 Blazer
Bad ground? Double check you grounds between the body/frame/engine/ battery.
Scott91370
Burleson, Tx
Scott
Sierra1500
I like the ground idea - it happens A LOT.
How are you measuring voltage at the headlights and how many volts do you have?
Auburn, Washington
No LEDs until you figure out the problem, which sounds like ground(s).
Do a little readin on here. This subject is discussed regularly. You’ll learn where all the grounds are to check/clean up. That’s where I’d start.
imyourhuckberry
