Anyone running wipers bigger than 16" oem?
Squarebodies have the aerodynamic efficiency of a sheet of plywood and we're discussing the additional induced drag on an extra inch or two of wiper blade on the mounting pins? It's hard to make this stuff up. Put an LS (with 8 good cylinders) under the hood and you will forget all about your wiper woes.
well im not sure who you are talking at but I said what I said because of the the potential damage to the wiper plastic thats used to connect to the wiper arm
The pin is fine, its just a small little portion. bucket said hes not experienced that as a weak point, and cheap wipers have weaker adapters and most people here are talking about quality wipers
So seems like..you just wanted to make the LS swap recurring joke
2/10 low effort
i know you got at least a 6/10 or 7/10 retort, common!
SquareRoot
2/10 low effort
:pedobear::shrug:
SquareRoot
But, but, that’s not what the 73 brochure says!
They were designed with the aid of a COMPUTER!
:laughing1:
robracing85
