Crazy Canuck!
Rusty Nuts
B.C.Canada
Keith
1500 Sierra
Hello all! I recently started a project getting a '80? GMC Sierra 1500 back on the road. So far the only things I'm still having issues with is a front brake sticking on, and no headlights... Lol, so I'm sure I will have some questions to post in the next week or so...
I've gotten some ideas as to where to look next from reading older posts so that's awesome! Appreciate the forum and this great pool of wisdom!
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
animal
Lee
c10 silverado
350ish
:welcome:
Strick
Dunn, NC
Harold
C20 Crew
Welcome from the Tarheel State. Look for a collapsed brake hose on the sticky brakes & kick the dimmer switch a few times to wake the headlamps.
HS
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria.
Rusty Nuts
B.C.Canada
Keith
1500 Sierra
Thanks for the warm welcome everyone! The headlight problem dose seem to be the dimmer switch, seems like the easy thing to do is put in a floor switch as it's pretty tough to get at the one on the column...
The brakes seem to be a bit more work to deal with, old flare nuts stuck to the line here, damaged shoulders on nuts there... You know the drill I'm sure... Lol. If I can't get 'er figured soon I will make a post with a more complete breakdown of the issue.
:welcome:
75 Chevy SWB 4x4
NE Oregon
Doug
K10 4x4
Welcome from NE Oregon!
Actually, the dimmer switch on the steering column isn't that hard to fix. Of course, I've only had Chevy steering columns apart umpteen times over the years to tighten up the tilt or to replace certain parts in them. Just look at the dimmer switch lever and see if it's contacting and moving the linkage that touches the rod, and that the rod is actually in the dimmer switch halfway down the column.
Hard
