Looking for a "good" used 30 spline front output NP205 CV Flange yoke for my 1981 K30
REK1
West Central Indiana
Robert
K30 4X4 dually
Sorry if this is in the wrong place as I don't have the credentials to post in the wanted threads. I am looking for a "good" used 30 spline front output NP205 CV Flange yoke for the double cardan joint on my 1981 K30 For some reason when doing a search I can find new and used but seems less common than the 32 spline and I think its rather expensive when I do locate one. If I need a picture I can get one later.
Appreciate any leads in advance.
Regards,
REK
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Regards,
REK
I'm sure off-road designs has what you need.
REK1
Robert
K30 4X4 dually
Appreciate the link Drifter. Unfortunately they only offer the 32 spline style.
The 32 spline is what everyone upgrades to. Did you call them. Stuff like that might not (often not?) be listed on the website.
REK1
Robert
K30 4X4 dually
I have not called but I will. Thanks,
tman
Stockton California
Tim
K1500
Hey I have a 205 taken apart at my other house , I'll drive out and look at it and let you know. It's complete just taken apart, they are bulletproof.
REK1
Robert
K30 4X4 dually
Thanks Tim! Not sure why this one is loose unless it was from prolonged use with the cardan joints being so bad. Bad as in no needle bearings in two caps on each u-joint.
Bowtie-dad
Wyoming
Brad
V35
7.4l
Denny's driveshafts
geardaddy
st. paul mn
mike
several
Regards,
REK
If you still need the 30 spline front yoke, give me a call at 612-309-3999...
Hard
