1985 4x4 700r4
Jeffrey Roberts
Blue Springs
Jeffrey
I have rebuilt my 85 700r4 transmission. Replaced all seals, clutches, some steels and detent cable. It has 1,2 and third gear. Some times 4th and then lockup. I need some direction to go in to troubleshoot.
Zelph
Nevada
I would look into the 3-4 shift valve/piston whatever it’s called and check it to see if it’s hung up.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
How many miles since the rebuild? If the 1,2, and 3 shifts are normal, with no other issues, put the shifter in 3rd gear, drive the truck at a speed well beyond where it would make the 3-4 shift, and put the shifter in 4th. If it shifts, upshifting/downshift a few more times. If the valve is a little sticky, sometimes that can free it up.
If not, pull the valvebody and check for sticky/hanging up valves. When you reinstall the valvebody, carefully torque the valves in a circular order. The early 700s overhaul manual outlined a specific bolt torque sequence, but most likely if you tighten them evenly and correctly you will be fine.
Jeffrey Roberts
Blue Springs
Jeffrey
Thanks. It has less then 100 miles on rebuild. I will try what you suggested. Thanks again.
scubacarib
bastrop tx
john
c15
i have found Lucas transmission fix works wonders i put it in every build this is a pic of the one i use they make another but i have only used this and it works
t
C20NamedWaylon109
