Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
A determined thief will get into the truck/car given enough time. They would REALLY have to want it to spend a lot of time getting into it. And if they really want the truck, no security system will prevent them from towing it away. They will disable whatever security system you have installed in their privacy and at their leisure.
The idea is to make the truck as unappealing to steal. For the price, it’s hard to beat one of these LED in the defroster vent in the dash, easily seen thru the windshield.
https://shop.advanceautoparts.com/p/dorman-conduct-tite-red-alarm-led-light-indicator-84918/22144508-P
connect the power wire to a orange wire (dome lamp feed is great) and the negative wire to a IGNITION feed (a pink wire works). It sounds wrong to have power on both wires to the LED, but unless the led has a ground, it won’t work. The led will be supplied power at all times thru the dome lamp feed, and will get its ground thru any of the countless accessories powered by the ignition switch.
Lock the doors when your away, make sure to park in a well lighted area with lots of people, and maybe a kill switch to disable the ignition. Most thief’s won’t stick around to figure out why the truck the just broke into won’t start.
BTW, hot wiring a car/truck isn’t like you see in the movies. For one thing, there is NEVER enough wire to pull out from under the dash to easily work with!! All it takes to drive off with theses trucks is a ball peen hammer. Smash the column to the left of the lock cylinder, use a small screwdriver to pull the ignition switch rack gear, and drive off. It took longer to describe than to actually do it.
