I’ll list the parts that have worked for my ‘75 K25. YMMV
- Original SBC steel fan and shroud, which was part of the factory HD cooling package
- severe duty fan clutch
- Stewart high flow water pump and 195 degree high flow Robert Shaw thermostat
- Champion aluminum 3 row (I think) radiator from Jegs. It was the CU161 equivalent.
Last weekend it was about 85 degrees here and I had the truck idling while I added some R134a and cleaned up odds and ends in the engine compartment. It idled with A/C on for about 40 minutes, and the temp on my mechanical aftermarket gauge stabilized at about 197 (maybe the 195 degree thermostat is a little lazy). Highway temp reading is similar.
