electric choke/ operating in reverse at start up
gordo9
idaho
gordy
Sierra 2500
1985 350/ quadra jet 4 bbl. emissions removed/ vacuum lines still installed.
Scenario : get in turn key, if its cold out choke light doesn't come on ( 1 pump choke plate does set). If it warm out or warm engine choke light comes on.
it"s one wire to choke, so it can't be reversed with anything??? wire appears to be connected to oil pressure switch? on side of distributor. position about 3 o'clock looking at distributor .
carb is rebuilt, high low advance all set. when in the shop operates as it should other then start, but suspecting that when driving choke is on too some degree. 5 mpg and a little sluggish under load. and thoughts and suggestions greatly appreciated.
Turbo4whl
Downingtown, PA
Wayne
The choke light works backwards from what some other systems work. Turn the ignition on, power is fed to the oil pressure switch. The light is wired to that side of the switch too. Non running engine pressure switch is open, current to the light only. Start engine pressure switch closes, current to the choke heating coil. The light goes out because the bulb resistance is higher than the choke coil. Electric flow, path of least resistance.
The fact the choke does not set could be an adjustment or bad coil parts.
Low oil pressure, choke oil pressure switch is bad( and it's not typical oil pressure switch normally open closes with pressure) open circuit to choke oil pressure switch.
gordo9
idaho
gordy
Sierra 2500
Thanks for the schematic Turbo4whl. I'll test the switch Ricko1966
Dejure
Eastern Washington
Kelly
C15
When I got my rig home, after it sat for a few days, the battery would be dead. Pulled the negative cable and put a light between the cable and the battery. The light lit, indicating a drain.
I isolated the drain to the choke. Someone had tied it straight to the battery. This meant the battery was always being drained via the resistance of the choke circuit.
As others noted above, there should be no completed circuit (power to the choke) with the key in other than the run position.
When the ignition is in the run position, the power through the choke causes the bi-metal coil to heat, open the choke, and hold it open.
Once the key is off, so power is removed, the choke coil cools, causing the choke to close, as the coil unwinds.
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
I printed some choke pages off charm.li for my 86 a few days ago.
(things that I have forgotten about since about 2004)
here is GMC 1985
duncan_schawalder
