Bruce Wingate
- May 20, 2021
- Long Island
- Bruce
- K10
I've been quiet for a while - vacationed someplace warm.
My last tech support call with Holley said to power the fuel pump via a relay and run a ground from the pump directly to the battery. I don't see the point, but I spent today taking care of the relay. My wiring is out of control with too many things hanging off the battery - will be putting in bus bars probably on Monday. Next call with tech support will be for RMA's to send the ECU and harness back for checking.
@Ricko1966 - I can actually just swap the plugs for injectors #2 and #4. I'm nervous about playing around withthe firing order and either messing it up or forgetting to switch it back. I'm at a loss as to what this would show me - I already know that it is either the ECU driver or the wiring harness. Would doing this swap add any additional information? Especially since I've already swapped over the injectors, coils, plugs and plug wires.
