Wtf Bfg allterrain split
woodsrider250
Fredneck, MD
350-Qjet
Walmart techs...
Can't fault them. Any tire tech will inflate to the vehicle specs, not the tire max specs....which is exactly what they should do. Now, throw off-spec tires on your stuff, then read up on how to visually tell if your tires are inflated properly....Vehicle spec is still the starting point.
77 K20
Montana
K20 5" lift
HT383 fuel injected
25 year old tires? Wow.
350runner
tx
Ceasar
Not all just that one. The others were 06. Got 2 new ones today and will get another 2 little later. So what is the recommended psi for these Bfg all terrains? 31/10.5/15
77 K20
Montana
K20 5" lift
HT383 fuel injected
What width wheel are you running 8"? What is the max pressure on the sidewall? 45?
The best way I have heard to figure it out is get the tires warm then use chalk and mark a stripe across the tread on at least 1 front and 1 rear tire. Then drive in a straight line. Keep looking at the tires. If the chalk wears off in the middle first you have too much air. On the outsides? Not enough.
350runner
tx
Ceasar
Width is 8in.
Max psi is 50psi
350runner
tx
Ceasar
I will buy some chalk Fri and check.that sounds like a great idea
Dam dude says its made in 88... Hell I just popped out 5 years earlier
Maybe not, it could have been '98 too. Before 2000, the last digit was only the year and the decade was not specified.
350runner
tx
Ceasar
Ok well lesion learned the hard way. Now ill check the dates b4 worrying about the tread... Now time for the chalk line test this Fri. Still have two 06 tires on front (they wouldn't mount then on back... Idk) and nw ones on back both will get the chalk line test
Driver4r
Nebraska
Trevor
k10,c20
Ummm, this makes me want to check my datecodes also. I have the older bfg straight side biters.
Ive had mine rolling atleast 110 befor. lol
Did 120 down the highway 1 time.
Wow.........2003......................
350runner
tx
Ceasar
Trust mei never thought this would of happened....
Discount tire tech days Walmart did not balance the tires right:-( he said they left off about 4Oz. On each... So yeah its on Walmart
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Discount has a corporate policy to not touch a tire that is over 10 years old... And there is no way of telling how out out balance a tire was when it is failed.
If it were me, I'd run 40PSI in those tires. Remember, MAX Pressure is 50PSI. That doesn't mean you run them at 50PSI. That means 50PSI is max pressure. I'd run 40 PSI for my daily driving. If I was going to be carrying a heavy load I might crank it up to 45-50 depending on the load. If you run Max Pressure on a light load, you'll likely get the feel of driving on solid rocks.
350runner
tx
Ceasar
The tire was off the truck so that 10 year rule went out the window... The thing only had one small weight on it. The rest of my tires were way off too. What's up with the Wally world defenders :)
Driver4r
Nebraska
Trevor
k10,c20
I run the exact tires at 45. And yes, it rides a little rough lol, but i have yet to squat the backs.
350runner
tx
Ceasar
Thanks I'll give it a shot
mjek421
