Won’t start
Martin1313
Vidor TX
Martin
Woke up 1:00 am Thursday tropical depression Imelda rolled in. Found water bumper deep on my 73 c-20. Tried to move it to higher ground. Truck cranked but I guess the fan was already in the water. Truck sits in water till Friday. Now it doesn’t even click. Where should I start?
Just a guess:
Make sure the battery is fully charged. If the water was that high, it could have reached the positive battery cable where it connects to the solenoid. That could've created a short to ground which would drain the battery.
The starter might be shorted internally as well.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Bang on starter with hammer... dirty water maketh sticky solenoid.
Dmack
Central OR
Dave
Maybe pull the plug and make sure no water entered the engine. Not sure how high it got...
Dan Miller
K15SG
Indiana
Daniel
K15
Luck be with you. All replies so far are possibilities ...Hoping for a good outcome for you
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I’d put new oil in it. Clean the inside of the distributor with wd40. Pull the wire from coil to dizzy. Pull the plugs. Crank water out. Replace plugs. Test starter, replace if necessary. Try again.
joseph916
