Wiper arm removal… Don’t laugh!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
There is probably some special tool for this and mine are probably stuck on with a little bit of patina, but I figured I’d ask anyhow. The driver side wiper arm came off OK, but the passenger side is being a B word. My eventual goal is to remove the cowl and vacuum out 30+ years of whatever is down there. As you can see in the picture I put a few dings in the wiper post already and figured I’d better stop and ask before I broke something. The videos I found on YouTube aren’t for this exact truck. The ones they are for our own vehicles were they don’t mind prying against the cowl for whatever reason.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
That little clip hanging out is the key.
Spray some PB Blaster or your favorite penetrating oil up into the shaft/arm mating area and let it sit overnight.
Wrap one end of a rag around the base of the wiper arm and pull with a wiggling motion.
Patience. It will soon come off.
Been there, done that.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Sounds like a plan. I’ll definitely put a coating of some waterproof grease on there before it goes back on.
Craig 85
Nashville, TN
454/TH-400/NP205
From the picture the arm looks torqued slightly. I would push down first to center it again on the shaft. Try to use more upward pressure near the retaining tab side since the other side is under tension from the spring in the arm.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Okay, I’ll give that a go too.
chengny
From the image shown above, it looks like the cap is cocked on the capstan...
Uh oh, never mind - just saw that Craig already got it.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Are you moving in in the right direction?
I used a tiny pick and pulled it away from the post so it’s no longer resting in the recess below the splines. Same technique as the driver side, but the driver side came right off.
Is that correct?
Dutch Rutter
Independence, Or
Joshua
Is that correct?
Yep, same exact as the other side. I found it easier to raise the arm from the windshield and use that to lift the one side while using a flat head screw driver to pry against the clip and lift it away in a small wiggling motion.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
That’s kind of what I was doing. I’m letting it soak per previous suggestions. I have a knack for pulling too hard and breaking stuff on accident.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Don't break your crank pulling so hard...
Patience Grasshopper. Except for automobile racing, the race goes to the slow and steady.
Slugnutty
House
Gus
Just pulled off the arms on my 84 C-20 and I needed to MAKE SURE they came off straight, just as soon as I twisted, pushed, pulled the arm it bound those tiny fine "teeth" and did not budge.
Straight out off the stub they clip to and had very little problem - same for getting them back on directly back on to the stub that drives the arms no twisting, pushing, pulling until the clip snaps back in to place.
Good luck friend, I can already hear me swearing at them both on and off too....
1987R10Man
