Window Gutter Trim 86 K10 Siverado
Daniel Morris
Virginia
Daniel
K-10
Once you put the base of this item on how do you attach the trim. Special tool?
Not sure why this was originally placed in the introduction subforum but I’ve moved it for you :waytogo:
No special tool. Put trim up, line up holes, screw down little bolts, done
Daniel Morris
Virginia
Daniel
K-10
No special tool. Put trim up, line up holes, screw down little bolts, done[/
Daniel Morris
Virginia
Daniel
K-10
It has a piece of base that goes on the truck..........then the trim goes on it somehow. It is so difficult the snap on it appears to need a special tool. It also appears the curves from the base and the curves from the trim are not the same? Came from LMC
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
I believe he's referring to the thin stainless trim piece that goes on top of the black gutter which gets screwed to the cab.
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
It just snaps on, start in the centre on the curve and work it out to the ends. Use the palm of your hand.
Check you tube for an LMC video.
still not sure, then. My OEM pieces must not have that? :shrug:
eskimomann209
Modesto
Marcus
My oem had one. At least I think it’s oem it was out on my 73 looooong before my family got it. You can bend the steel off the “base” to remove the screws easier. I just wouldn’t do it. Steel tends to work harden and break after being manipulated too many times ....
chengny
X2 - requires a 1/4" wrench IIRC.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Dollar waiting on a dime
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Maybe I need to see a pic then. I must not be understanding something correctly lol
The drip rail is made of two pieces. One black painted steel piece which is the actual gutter and one stainless trim piece that goes on top of it.
I know what you're talking about now :rolleyes: Then my suggestion to the OP is attach that stainless trim to that black steel piece then attach it to the body. The stainless piece should just pinch on to the steel piece. Shouldn't be rocket science with no need for a special tool.
ehernandez
