86 c10 to k10 swap 4l60e w np208?
86devh
Wichita ks
Devan
Hello all, I am starting a frame swap on my 86 c10 onto a 87 k10 frame. The donor had a 700r4 and np208. My truck has the th350c, and i have thought about putting the shorter shaft in the 350 and using it or cutting the 2wd shaft? Have thought of using a 4l60e. Forgot to mention that it is ls swaped w a 2002 5.3 so i already have a computer on the vehicle and so i was also wondering if i can use a 96-97 4l60 because it has the 4 hole tail housing. I have read some other threads and i believe that i cannot use the older 4l60 w the newer computer. I also have a Dakota Digital speed pulse through adapter the a vss isnt an issue. Thank you all for your insight!
Scandia
