Wind noise is running me stir crazy
christopher jones
Natchez ms
Christopher
I hope I am in the right forum. I have so much wind noise in my truck I can’t stand it. I can’t tell where it’s coming from because I am driving. I guess I need to person on the passenger side. I get up to 50 mph it’s crazy. I was wondering about the side vent window rubber? I hade my truck painted and doors removed, could they be out of line? I need to know where to start, is that common in these trucks
If it's that bad, you should be able to find the offending seal (or seals) with a visual inspection and spraying that side of the cab with a water hose.
Camar068
10 yrs Air Force
mine does the same. I can tell I need all glass seals though so it's obvious to me. If/when I get it fixed I'll be in heaven cuz it's never been quiet.....have to yell at others to have a conversation lol.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Cut the mufflers off, then you won't hear the wind anymore ;)
Seriously though, I would do a good visual inspection and see if any of the seals are not making contact to their mating surfaces.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Have some of you talked about doubling up your door seals with made-to-fit seals and then using hardware store weather stripping to help combat wind noise? If not, maybe I dreamed that and if so, just move along. These aren’t the droids you’re looking for.
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
I had the same problem. Adjusting the doors so that they close firmly did a lot. Now i have to slam them a little harder but it really helped.
Then i added this, which also helped a little.
ropp1969
Idahoe
Ropp
6.2 diesel
My passenger vent window has wind noise. Putting a cardboard “shim” beneath the vent window handle helps.
yevgenievich
Viktor
sad
very sad
less sad
There is a factory seal on the door similar to what you added. Was option on 70's trucks. I added them to my 91 suburban
MrMarty51
Eastern Montana
Martin
Easiest way to find air leaks is with smoke. A fireworks punk, an incense or someone that smokes. Have them drive, You take Your smoking device and move it around near the windows and doors. You will soon see the smoke being pulled out.
Dont forget the windshield too.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
That above the door seal was available on all squares throughout the years. Maybe someone can chime in on what level of trim options included them or what the rpo code was for them.
Can't help much on that, seems I grew up with and only own low level garbage that was not worthy of such fancy options.
Craig 85
Nashville, TN
454/TH-400/NP205
LMC shows 79-81 had the upper door weather strip. #3 is similar to factory and is what I bought for my truck. I'll install them after I paint it. #2 is the stick on style.
FireTruck1984
Michigan
1984 and 1984
New door seals and a second seal on the door makes a big difference, I added the seal to most of the door.
aaron06
