Will 20 Gallon Tanks Bolt In?
97350
Canada
Duane
C1500
I have an 83 long box 2 wd with 16 gallon tanks.Will the 20s bolt up and use the same sender?
Driver4r
Nebraska
Trevor
k10,c20
yes, but you should already have 20's
transportjockey
Albuquerque, NM
Nathan
454 V8
I have one twenty and one sixteen.
Sent from my SPH-L720T using Tapatalk
oopsman_09
Nampa, ID
Aaron
sierra classic c1500
my lwb has 12 gallon tanks :(
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Same here, but that's only because I needed to replace one tank, so I opted to upgrade it to the 20.
As mentioned above, straight bolt in, holes are already in the frame. You will need a 20 gallon filler tube, or to modify the original to fit.
Driver4r
Nebraska
Trevor
k10,c20
Was this a later thing?? Dont most 73-80 have 20's?
Adis
