Wich oil pan do I need?
Ypsik10
Ypsilanti mi
Chad
Put my stock oil pan off my 305 onto my new 350 (1974 block) there is no provisions in the block to press in the dipstick tube like the 305 so I'm guessing I need one that pressed into pan? Has anyone run into this problem or no what pan I need? It's going into a 79 k10.
Ypsik10
Ypsilanti mi
Chad
Ok I found were it goes on the block it seats right next to the head reset driver side but still isn't going to work with this pan
MikeB
North Texas
Starting with 1980 engines, GM moved the dipstick to the passenger side. Your 1974 engine will need a 79 or earlier pan. This is a very nice one, but you can find cheaper versions, or maybe a used stock pan somewhere.
https://www.summitracing.com/parts/mil-30700
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I just bought one of those milodon oil pans.
And while I was at it I threw in their 20 dollar matching timing cover. lol
74 Shortbed
I may have one laying around..
Ypsik10
Ypsilanti mi
Chad
O rieleys had one 50 bucks!what gaskets do you guys prefer? Bought a rubber one peice.. Never used one..can still return
74 Shortbed
Wish they would have come out with the one piece 30yrs ago, lol..
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I've been using one of the blue fel-pro ones. Haven't noticed any leaks with it... at least nothing as bad as my cork valve cover gaskets!
CSFJ
Make sure you got the correct one. Iirc, there were two different thicknesses to the seal at the front (and rear?) of the oil pan.
74 Shortbed
Well then I guess I'll use it!! Any tips trucks?
If your pan and timing cover are like new at most just a dab of silicone on the corners(check fit)I've used them with nothing at all and never have a leak, re use them over and over never an issue. If your pan and cover are not the best then smear a bit of silicone across the ends..
74 Shortbed
Yep, thick and thin, depends on the timing cover..
gmmatt81
Knoxville, TN
Matthew
4.3 L
Agree with using a 79 or an earlier pan. Cheap indeed!
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Definately go with the one piece oil pan gasket. The multi piece gaskets always seem to leak. I replaced my leaky oil pan gasket with the one piece (blue rubber) with the motor in place and didn't even have to lift the motor off the mounts.
I applied a thin film of red rtv to the block and the pan...let it get tacky, then installed the gasket. Leak free seal!
K5Chris
