Whutizit ??
Ronno6
South Mississippi
Ron
1984 C10 305
The first pic is the oil pressure sending unit,right next to the distributor.
Then what the heck is this, and do I need it on my new 355 ???
78C10BigTen
pennsylvannia
C10 BIG TEN
Top pic is indeed oil press. I myself am not sure on the second
eskimomann209
Modesto
Marcus
Top pressure gauge helps control the carb
The lower one is what actually makes your dash oil gauge function
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I guess you could wire the choke heater to the ignition switch, but it would be better if it's only operating after the engine is running.
eskimomann209
Modesto
Marcus
I may be wrong it’s happened before
But the top one is the pressure switch
For the carb / fuel delivery etc...
the lower one is actually the sender that runs the gauges
But what do I know
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I might just be the lunatic you're looking for...
Yep, 2nd one is needed for the choke to work. It also controls the Choke light on the dash too.
Ronno6
South Mississippi
Ron
Looks like I'm usin' 'em both! Thanx....
73c20jim
Tombstone, AZ
OOPS!
Adis
