which front axle should i use?
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Instead of changin all the axle stuff around to match the t-case why not just change the t-case to a chevy side drop and then yhou can use easily avaliable chevy axles. I think Hotrod could help me on this but a NP208 i think will bolt to the newer t-case adapters.
I agree, just swap the t-case and run a garden variety Chevy front axle. The '89-'91 Burb/Blazer NP241 will have the output for electric speedo and bolt right to the adapter that's already on the 4L60E.
Joshua8336
Dirty South AL
Joshua
i wanted to be the first square guy to use a ls motor transmission, and transfer case. but guess it's too much work to do. so i'll snag some dana's from a older chevy and buy an adapter to run the 89+ transfercase on the rear of the 4l60e? i will figure out a way to run the ls motor transmission and transfercase one day, i'll hold myself to it.:baby:
Don't think of it as an "LS transfer case" because it really has nothing to do with being behind an LS motor. It has everything to do with being in a newer body style truck. Not better, just different.
Your current adapter should work, because GM went with the standard "round 6 bolt" pattern back in the 80's. Worst case, the T-case is not clocked right and you have to buy or make a clocking ring. I doubt it though. Chances are good the t-case will sit just right, or up a little higher but that won't matter since you plan on a body lift.
Joshua8336
Dirty South AL
Joshua
thanks guys! one last question, which chevy transfer case is best, electronics aren't an issue because i can use the dakota digital vss buffer box to get my speedo working.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
NP205 is the best of the best. NP241 might be the best choice for what you're doing though.
Just a warning here. I'm about to close this thread down. I'm seeing the dirty 4 letter F word used a bit to often here.
you must be reffering to Found on road Dead?
That would be correct !!! What the **** else would I be speaking of??? :rofl:
Believe it or not, I try not to use ^^^^ that word in print often either, but it fit here.
Joshua8336
Dirty South AL
Joshua
:lol: you'd really close a thread for using found on road dead?
NO, I've never closed a thread here. Been a couple that were not good for the forum, and I deleted the threads, but NO, it's the humor factor is only reason I mentioned it. Some of us don't care for the other brands, some of have the have the other brands, I am one, that still has a F$RD.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Probably alot easier to find the 78/79 f250 dana 44 front than it is to find the ultra rare 90/91 burb and blazer 241. They are out there, but they are not at all easy to find. I'll setup you one for $500 with a slip yoke eliminator and a high angle driveline cv flange rear output.
nvrenuf
Mobile, Al.
Winner Winner, chicken dinner!
78 & 79 Fords (only) have the same spring perch width so these leaf sprung axles are a direct bolt in to a Chevy. Add crossover steering and it's so easy a caveman could do it. :grd:
78 & 79 Fords (only) have the same spring perch width so these leaf sprung axles are a direct bolt in to a Chevy. Add crossover steering and it's so easy DAVE could do it. :grd:
WOW, didn't know that. Awesome info.
Oh, and I fixed that up there in yer quote for ya !!! :High 5:
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Yup, my 80 k2500 chassis its getting a ford 44 to mate the gmt400 drivetrain it is getting.
adhkjashda
