Wheels
crpntr78
Missouri
Hello, what all year stock wheels will fit an 82 k20? Will Ford or Dodge wheels fit also? Seems like they used to back when. Thanks
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
yes. 2010 is the year gm changed the bolt pattern so most will fit before that depending on backspacing and brake size. older Ford and dodge wheels are lug centric and will fit but they have larger hubs. ford changed in 98. not sure when dodge moved away from the 8x6.5.
Yep, Ford and Dodge wheels will fit GM, but GM won't fit Ford and Dodge. This is due to the hub opening being bigger on the F and D. Most 8 lug aftermarket wheels will fit all of the above because they make the hub opening bigger for that purpose.
I picked up the 16" wheels for my K25 (originals were 16.5") from the pick and pull for $25 each. That was a few dollars cheaper than the yards where they had already pulled them off vehicles. I could also that they had actually been mounted and fit on a square body.
Bowers31
