what is it.
78C10BigTen
pennsylvannia
C10 BIG TEN
Can anyone tell me by looking at it what rear i have and what gears it may have? Keep in mind its the stock rear.
78C10BigTen
pennsylvannia
C10 BIG TEN
Lol you asked that's what it is a GM truck 12 bolt. I actually wasn't being a wise ass .........this time:D
Lol well i know its a 12 bolt. Im not very knowledgeable in rears n gears, is that a good one or just a run of the mill?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It's what they used until the 10 bolt. It will have 30 spline axles and a marginally bigger ring gear then a 10 bolt but there are a few things a 10 bolt has ove the 12 bolt too.
12 bolt 8.875
10 bolt 8.5
78C10BigTen
pennsylvannia
C10 BIG TEN
12 bolt 8.875
10 bolt 8.5
Are they durable? Are they junk? Are they popularly looked for?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I have a 12 bolt in my black truck, all be it it has a posi in it and it was cheap. If I would have found a posi for the 8.5 first I'd have a 30 spline 10 bolt in it. Strength differences are marginal between the 2. Carriers are what makes the 12 bolt a pain in the ass.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Assuming it the gearing hasn't been changed, the RPO sticker is what you need to look at. The code GU* should be the gearing it came with, and if it came with limited slip, it should have a G80 code. For example, mine is a GU6 (3.42) and a G80 (Eaton Gov-Lock).
78C10BigTen
pennsylvannia
C10 BIG TEN
It does say G80 but thats all i see.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
You're right. I guess they didn't want to tell you. My sticker is the one with just the codes listed and not the definitions, though, so I don't know if that makes a difference. I guess you'd have to count the ring gear teeth and divide by the number of pinion gear teeth to get the ratio if you plan on servicing it anytime soon. I know you can also find it by turning the driveshaft turns compared to how many turns the wheel makes or something like that, but I can't remember the trick for the life of me. Hey, but welcome to the positraction club. That's pretty cool.
78C10BigTen
pennsylvannia
C10 BIG TEN
That is the glove box sticker, i was told it had one on the inner fender but it doesnt. So that g80 means it shouldnt be a 1 wheel peeler? Lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I don't think the gov- bomb was in the 12 bolt that should be a clutch type posi. +1 for a good posi and + 1 for 30 spline axles.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Wear good boots, you'll need them.
Ls85c10man
