Carb'ed Vortec 350
Finally got to putting in the new latches for my vent windows. Old pitted chrome out. The plastic and rubber in the old ones were crumbling away every time it was touched. New chrome in. After finally getting the drivers side figured out I was excited to get the passenger side in and discovered the previous owner sealed the bottom of the passenger side vent shut with some type of silicone or caulk to keep the breeze out I reckon.
(Sad face emoji here)you can see it in the passenger side pic. So I figured out how to install the new latch without opening the vent and settled on one working vent with a new latch and one sealed vent with a new latch. At some point in the future I am replacing or refurbishing the whole assemblies.
Um, unless it's a camera angle thing, but it doesn't appear to be, those vent window latches are not correct. They're supposed to rest on metal between the window and vent window, not reach past that metal to rest on the window.
mtbadbob
Montana
Bob
V20
You are correct, sir!
mxer147
Colorado
Jack
k20
New greased bushing for the door hinges.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
No metal from the latch touches glass. The latch swings back past a jut out on the stricker plate and clicks at the bottom of the jut out. If you look close you can see how the striker plate has a "ramp and drop off" jut where the nub behind the latch handle lands when closed. At least this is where the old latches landed and where I assumed they are supposed to stop in full closed/locked position. The lock button does pop out here. 1987 maybe slightly different or am I totally wrong?
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
After opting to drive the truck today I immediately took a look while it was warming up and nudged the latches up to the top of the "ramp" on the striker plates and the push button popped out to be able to depress easily. This seems to be the way it should work. The button is easy to push, not hard. Makes sense. Thanks guys, this is why I am on this forum!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
You have whole replacement assemblies or latches?
Whole replacements. I know a guy that has a bunch of them in a storage room. So I got both sides. They work right now but need to be replaced. I'm waiting to find a new driver's door then I'll do it. I have a pass door in my shed bit need drivers side door.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Any chance your guy has drivers and passengers for a 1987 in good shape, that you could get a hold of and ship?
Carb'ed Vortec 350
Now I am on a computer, looking at the photo again, I see a nub that appears to be resting on the "catch" of that metal I was talking about. Is that correct?
mtbadbob
Montana
Bob
V20
I have a set but it'd be expensive to ship to you. Power or manual??
82sbshortbed
Fuckemall!!
SE Texas
Doug
I'll see if he does. I'm pretty sure he does. I'll let you know when I find out.
dhartman
michigan
daniel
c15
Pulled the top off for more room while working on the interior. (I’ve used it a time of two for a paint stand.
Whats goiing on with that hood would love see some more pics of it looks awesome sause...
82sbshortbed
Fuckemall!!
SE Texas
Doug
Thanks @mtbadbob ! Actually I was looking for vent window assemblies to replace the ones I have.
Here's the 2 I bought. Much better shape than what I have on there. As soon as I get the new door I'll put them on.
Ajax19
Socal
Ajax
Bumped my idle up truck was acting like it wanted to stall in gear I remember awhile back I dropped it when I was dealing with it dieseling(it was the ethanol fuel) I'm thinking it's just all the cold and wet days drove to the local watering hole and back and drove good
Andrew45
