45tt
Florida
MJ
GMC Sierra Grande K15
Currently in the process of getting my laundry list of things done that I’ve put off for years. A lot of leaky gaskets and brake work. It sits too much and seals dry up and brakes got hard. I really need to regularly start it and drive it more often.
Installed Octane led headlamps. Amazing difference and still look stock when off.
Have you followed anyone you know so they can say if there's too much glare? Got a picture close up in daylight?
Washington
Installed all but one new grounds. And cleaned up a couple of fubars.
Good lord. I can’t wait to see that truck “done”. It’ll literally be a brand new truck
Washington
I might be wrong, but I’ve never seen a square hole washer. I’m assuming you’re working with a carriage bolt?
The square portion underneath the head of a carriage bolt has rounded corners- I imagine that if you got one with a close enough size that the corners of the square would just push through and bite into the washer as it is tightening down.
Apologies if I’m reading your situation wrong or out of context.
Yup a carriage bolt washer. Can weld it in. But it would probably be easier to throw a tack on the bed bolt.
I had a rounded off bed hole. Just tightened it up. And called it good.
hoagster
California
K10, 1500
5.3l
I bought and built a new bed, but I had a after market second tank to cut out, and who knows how muck road base, or oak had visited that bed, not to mention the tractor fubars. I would use the washer tack it. Things move tack the bolt too! Or put a six point tighten it and grind the edge off if you are going to use the bed and a shovel.
justhorns
Denver
Lee
I loaned my truck to a neighbor for his work as a carpenter. He was unable to break it, which is good. If a vehicle loaned out comes back broken, its not the borrowers fault. To make a car/truck reliable, try loaning it to people and see if they can break it.
mcarlo86
ND
Suburban
All the parts are on, only thing left to do is make all the lights work again, put the bumper on, and then I can finally turn some rubber down the road. Can't wait to get it all wrapped up
So awesome to see you fix up a long bed stepside! What are you going to do for a rear bumper?
waterpirate
delaware
v10
5.7 tbi
I put an after market cat on today. Am going to try my luck with the inspection nazis again this year. If it passes I am going to put antique tags on it. Never has to be inspected again as long as I own it! I have been driving it for the past year with expired tags. lol
Soundmound
North Central Washington
Dave
Scottsdale
Last year I was one of the lucky five nationwide to score a Forever Sharp black muscle steering wheel at discount. This year they released a bronze version that matches the truck and wheels so much better... Well, Cyber Monday when they were 30% off I nabbed one! I think it looks damn good and will really tie the truck together. Will likely sell the other one here in the future so be on the lookout.
starlinstephens
