Poppy 87
Bloomingdale GA
R10 Silverado
Replaced my oil pressure sending unit as it decided to blow out during a drive to the coast and leak alot of oil EVERYWHERE. First one I've had that actually blew out instead of just the threads leaking.
Was it a China made part? I've never seen one fail like that
Sent from my XT1254 using Tapatalk
Dutch Rutter
Independence, Or
Joshua
It was stamped Taiwan. I have had this one in two different trucks and the same engine and its probably 8-10+ years old so that might have something to do with it. Was definitely a new problem for me.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Took ol brown over to a buddies house cause he failed to park on flat terrain, use wheel chocks, or fully depress the parking brake on his prius. o_O
Of course the car rolled back pinning the jack he was using on the ground sideways and the rotor dug into the asphalt.
Had to use the truck's jack as a wheel chock and another I brought to pick up the big battery.
Brown just out there getting it done in the wilds helping another brownish goldish ugly color prius get back on all fours. :burnout:
SDJunkMan
Black Hills of South Dakota
Jeff
My son is up from Denver helping me, so we made prety good progress on the burb yesterday. Got the front clip and doors off, as well as most of the interior and a lot of small parts.
Came across this on the drivers side fender, not sure what it is, part of a trailer harness, or the rear a/c ?
Looks like some kind of HD power solenoid for the trailer harness.
Poppy 87
Bloomingdale GA
R10 Silverado
Perhaps a trailer mounted winch? Seen guys mount those Ford type solenoids in the engine bay for valve adjustment etc, but without seeing where the wiring terminates pure speculation
85squaredC10
Wisconsin
Jason
Looks like it may have been for a plow?. Pink wires running to the front look like heavy duty power wire.
Sent from my SM-G965U1 using Tapatalk
SDJunkMan
Jeff
I'm guessing trailer, wires head to the back, definatly not a plow, truck never had one. I was just curious since it looked factory, and I have never seen a harness like that before.
I've had a couple of people ask if it has an electronic speedo, but it has a cable. After pulling the gauges I see this green thing on the back of the speedo, never seen one of those before either.
85squaredC10
Wisconsin
Jason
Green thing has factory number stamped on it. Google it. My 85 has one. It is a speed sensor.
That's the VSS used in the 80's trucks with computer control.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
It's taking a bit longer than planned, but the new LS is finally in it's final place. Converting to a hydraulic clutch and putting a SM465 behind a LS has proven to be a headache, but I think I'll be happy when it's all done. Now for a bunch of wiring fun.
Poppy 87
Bloomingdale GA
R10 Silverado
Looking good! What engine mounts did you use?
Catbox
Peter
C20 Silverado Camper Special
So I forgot to take a photo of how the truck what actually sitting, so this photo will have to do for now.
Junior was trying to flex his cool truck and how it will drive through our ditch in the front yard last night when his buddies were over.
He did not use enough angle to make sure the low hanging trailer hitch would not grab the ground.
You can see the hitch in this photo.
It is all welded to the frame and hangs super low.
He got it stuck.
Imagine the truck with the grill pointed at the camera, that is the angle that it was pointing.
It sat there over night as the tire would just spin with nothing to grab.
Fast forward to this morning.
I got in the truck and started giving it hell as it was my grass that I was ******* up.
It took a bit of rocking it back and forth and a piece of wood under the tire that had no traction.
After some tire smoke from spinning on the wood I got it to start moving around and finally pulled the thing out of the ditch.
I told him to quit driving into the ditch like that.
Poppy 87
Bloomingdale GA
R10 Silverado
He got it stuck.
Good lesson for Jr. Now he should repair the lawn as a way to think about his exit prior to hammer down!
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
I got the adjustable ones from LSX Inovations. They're just like the other 30 companies that make an aluminum relocation mount. I just got the cheapest one of that style I could find. They kind of suck and I had to modify stuff to make it fit, but it put the transmission in the stock location. I talked to their tech support and they were pretty clueless but did offer me a refund if I wanted it. I'll probably swap them out for something better down the line.
BrianGarf
