78C10BigTen
pennsylvannia
C10 BIG TEN
New mirror glass a few mins ago.
Got lucky and advance auto only had the drivers side in stock. $8. Some say they're universal?
Anyway, the factory had about a gallon of silicone on the old one, so I siliconed the new one in the same fashion to keep it as original as possible. :D
(plus, the double sided tape that came with it was a fukin joke)
Sent from my SM-G930P using Tapatalk
Diggin the slip ons.... :happy175:
KilgoreTrout
Pennsylvania
Dylan
350ci
Oh damn i like those. Where did you grab them? Was it all 4 wheels? I just paid fuggin$2.99 a nut!!!!
Yep, all 4 wheels. 24pc set on Amazon.
EECCPP replacement lug nuts. 7/16-20 silver chrome bulge acorn 1.38" closed end long socket lug nuts for Chevy GMC 1961 to 1987
78C10BigTen
pennsylvannia
C10 BIG TEN
Hhhmmmmm... mine are 1/2-20??
KilgoreTrout
Pennsylvania
Dylan
350ci
Stfu, man, I'm old. :D
The funniest part is that I went out to get "real" shoes and they were an afterthought extra pair. They were on sale for $18 and I was like **** it...... they'd be nice around the house and stuff.
I liked them so much I bought 4 more pairs and kept them in the closet until I needed them. I've worn almost nothing but these for like 3yrs. LOL....
73c20jim
Tombstone, AZ
Took the old SOB to body shop to have floor welded in professionally. To repair all my f---ed up welds and finish the floor.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Went to discount tire today for routine rotate and balance. They discovered left front tire was separating. I saw it and I was very nervous about it. I have noticed a strange feeling in the front as if there was an issue but didn't think about tire. I purchased 4 new tires in August 2015. Little did I know that, at that time, 2 were already 3 years old and 2 were 2 years old when purchased. Man was I pissed. I didn't think about tire production code when I got them. Got 2 new today to replace the now 7 year old tires. I will never ever buy tires again without checking production date. The 2 I got today both have codes of 1619. Left the 6 year old tires on front. After thinking more, I am going back Monday and get 2 more new ones. Do not feel comfortable with them on truck anymore.
New mechanical fuel pump, added glass filter before pump, still ran like poo.
Pulled dizzy cap, cleaned up contacts. Pulled rotor, cleaned and checked for vac advance...no move.
Got pliers, made it move.
Got vac pump, advance moves fine now.
Slapped it back together, spun tires. Runs like a scalded dog.
Life is improving.
Did they put power window motors in doors before the outer skin went on?
How the heck do you get it out? More Googleing in store.
78C10BigTen
pennsylvannia
C10 BIG TEN
Life is improving.
Id be careful with that glass filter... they like to leak at the rubber and cause fires...
78C10BigTen
pennsylvannia
C10 BIG TEN
I found my lug nuts on ebay for about $13 a set of 20. I found a set of 20 bullet style for $22. Not sure what im gunna get lol
animal
Lee
c10 silverado
350ish
Life is improving.
They are really not that hard. I looked where @Old77 did the ones on his suburban and followed suit. Drop the windows just enough so there is no pressure, then undo 4 bolts holding the regulator in and slide the rollers out of the tracks then wiggle the whole thing out. I went back with both new motors and regulators in mine. Probably took me 1 1/2 to 2 hours per door to remove everything and then reassemble.
KilgoreTrout
Pennsylvania
Dylan
350ci
Yep, that's about right. Not nearly as hard as I thought, but they need to come through the hole where the door handle is. It takes some patience and getting the angles right, but not too bad.
animal
Lee
c10 silverado
350ish
Yep and after thinking I believe I had to undo the rod that attaches to the interior handle.
KilgoreTrout
Pennsylvania
Dylan
350ci
Yep! I just let mine hang there. Seemed to work ok.
Yep, taking that handle off makes it a lot easier. Once you know the combo it’s not too bad. The rear doors are even more fun especially when it comes to changing out the exterior door handles :rolleyes:
Snips71
