flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Looks like antiseize being washed off the starter bolts by an engine iol leak. That and if that starter has been flopping around under there it is wearing the aluminum housing so there could be some fine aluminum there too.
That makes sense.
The oil leak is next on my list. That whole side of my oil pan is leaking. Going to try the 1 piece gasket out, no idea what is on there now, probably multi piece Cork.
Hoping it is not the rear main too, is there a way to tell?
If it is the rear main i am just going to look for a different engine. Don't feel like doing the rear main on this tired Wee-O-Five. If i am going to pull this engine it isn't going back!
Sent from my Nexus 6 using Tapatalk
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Finished building new trans lines for my LQ9/4L80E swap, installed upper and lower coolant hoses, loomed up the oil pressure and coolant temp wiring, etc.
Still a ways to go on the wiring...
Stepside Billy
Lake Carmel, N.Y.
Billy
Trying to figure out my stalling problem. Once in a while the truck will just stall. No shaking, like I turned of the ignition. Replaced the IAC but still did it. Runs great though!
yevgenievich
Viktor
sad
very sad
less sad
ignition switch?
Georgeb
Wisconsin
George
K10 Burb Z71
Does it restart right away? If not is there spark? If not it could be a flakey ignition module or pickup coil.
flyboy1100
UsA
me
k1500
pulled oil pan to replace gasket. found a Rivet???? and 2 pieces of the lower part of the Piston skirt from #4 and #8.....will be doing some more inspecting tomorrow before i just put it back together for now.
and these are my starter bolts....got new ones on order at the dealer, they will be in wednesday
Stepside Billy
Lake Carmel, N.Y.
Billy
It starts right back up with no problem. Mainly at lights or when I shift into gear. I have to feather the gas a little with my foot on the brake.
flyboy1100
UsA
me
k1500
Washed it so i can put a for sale sign on it :/
Maybe start looking for a good shape used 2wd square....
Got no need to a 4wd one now.
87ChevyR10
Kansas
NA
NA
NA
Replaced all belts today. Wanted to do spark plugs and oil; but the bloody North wind and temps changed my mind. Maybe tomorrow.
On a side note, I noticed the steering gear box is wet underneath. I wonder how much longer it has before it needs replacing?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Finished up smoothing out the bed and had the bedliner sprayed in by Universal. Finishing up the final touches and getting it ready for the carshow in the next week.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Nice, looks great!
That looks great!!!!
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Installed LEDs into the 91' Burb cluster I put in my 88' for my LS swap.
attachment.php
attachment.php
rowdy_80
