Truck isn't starting after a new starter
Akabot98
Houston
Alec
V1500 Suburban
5.7 V8
Truck has been starting great after new parts (battery, alternator, fuel pump, and starter). Just the other day drove to the grocery store came back to the truck and it wouldn't start. It was making short clicking sounds and wouldn't turn over. Tried a jump and nothing changed. Headlights and everything else was working so it's not battery. Even took out the starter and put in a new one and same problem. Any suggestions?
87 Suburban 350 TBI
BigUgly469
350 CI
Perhaps the replacement you tried was no good... It's happened to me before
Sent from my SAMSUNG-SM-G930A using Tapatalk
87scotty
Central il
Andrew
V20
5.7 for now
And or neutral saftey going out
towman
harrisburg pa
jay
v10
check your connections at the battery, check voltage at the battery it takes 12.6 volts to make a starter work properly other items on the truck will work with less voltage start with the simple things first
Akabot98
Houston
Alec
V1500 Suburban
5.7 V8
Wouldn't trying to jumpstart it, start the truck in that case
towman
harrisburg pa
jay
v10
one thing i have learned from thirty years in the shop never assume anything and always check the simple things first, if you didn't have a good connection jumping it it was in vain
mistaake
SF Bay Area, California
Michael
Crown Vic
my 77 suburban was doing that intermittently - it was a bad starter. i put a remanufactured one from o'reilly in and now it's fine!
Rusty Nail
Rusty
350sbc
Whack the starter with a hammer and THEN threaten it. If it won't start actin right you should probably replace the battery cable.
Camar068
Kentucky
10 yrs Air Force
2nd that motion, and it could be the starter still as someone mentioned. As simple as a starter is to change out, take the tools with you to the parts house, have them exchange it under warranty, and change it in the parking lot if you have to.
RICHARDJOHN
NB
RICHARD
R/V3500
Same problem for me.Battery cable was gone inside the battery terminal connection.
Stepside Billy
Lake Carmel, N.Y.
Billy
Went through the same thing. Turned out to be a bad battery ground.
tweeter68
