Truck is leaning to one side ???
V20 4X4
Iowa
Mark
V20
6.2 soon to be 454
My truck had a 4" Superlift that had a real bad driverside sagg, 1.75" up front and a 1" sagg in the rear. I just removed the Superlift and went to a stock 4 leaf HD spring set up in the front and removed the rear blocks and replaced all 8 ubolts and all 4 shocks. The truck still has the dang driverside lean to it. It's not as bad as it was, but It's still anoying and I can't stand it. It's now 1" up front and about 3/4" in the rear. What else could it be? Maybe the body bushings???
marks86
Latham, NY
Mark
12v Cummins
Yes I would check the bushings probably all mushed and cracked, energy suspention has I nice poly kit for 100$
None of mine lean to one side. The C10 did, but the left front coil has a couple wedges in it to level it out... it was previously owned by a fat guy.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I know it's a lot of work but switch the front springs around and see if that helps. If you switched both front & rear your lean might go to the other side lol. Do you know the history of the truck? I.E. did it used to be a work truck hauling heavy loads or have a heavy toolbox on one side? Maybe a ladder rack with more weight on one side than the other?
V20 4X4
Iowa
Mark
V20
6.2 soon to be 454
The front springs are brand new. I just installed them two days ago along with 4 new shocks. The rear's are a set of stock 8 leafs. I would hate to go through all the work to swap the rears and have the lean go to the other side. That would suck!!! The truck use to pull a 5th wheel trailer at one time in it's life.
Is there anyway that the rear leafs could effect the front to make it sagg more then the back?
I'm thinking I will look into switching out for a new set of body bushings all the way around the truck. What brand should I get, and who has the best deal on a kit that includes everything?
Anyone ever done this ? If so did you have any problems removing any of the bolts? I would sure hate to bust off a bolt inside the floor. I had that problem with my 66 Chevelle, and it was a major pain in the ass!
crazy4offroad
Curt
K-10
350/SM465/NP205
Maybe look at the rear leaf packs real good and see if maybe the side that leans has a broken spring, sometimes it is hard to see. My truck had a broken spring for a long time and I never knew it until I swapped the springs out for 56" rears. My parking area isn't level so I probably never would have noticed any lean. On a truck of your model year the bolts may not be that bad, just depends on how much salty snowy roads it has seen in its life. You may want to go ahead and get the tap for the body mount bolts before you start just to be safe. By the way does your truck still have the front sway bar? I took mine off and if there's a slight lean to wherever it's parked the truck leans pretty good.
V20 4X4
Iowa
Mark
V20
6.2 soon to be 454
My truck was never driving in the winter, it is rust free. So I "should be ok".
Yes mine still has the sway bar. Why would you want to remove it? It's not needed ??? What would the benefit be of removing it be?
crazy4offroad
Curt
K-10
350/SM465/NP205
A stock height truck needs it. The front springs are negative arch and only has 2 or 3 leafs. But when you lift it they are positive arch and usually 5-spring packs, much stiffer and less prone to body roll. Also many offroaders remove them to prevent the sway bar from limiting front axle articulation. Opinions vary on the subject but I think the majority would agree, on a lifted truck the need for one is less important unless your local inspection laws require it to be in place.
When parked on level ground, measure the distance between the rear axle and the bump stops. If both sides are about the same then the springs are OK.
swagger
old house in WV
Steve
350/SM-465/NP-205
Do that^^ and measure the distance between body/core support and the top of the frame on each side find your problem real fast
Steve
78shortandwide
Denver
Tom
Check to see if the frame is leaning or if the body is leaning that will tell you what you need to replace
Steel6xliii
Phoenix, Az.
Henry
I've got the same problem. Both frame and body leans evenly to the right. I've swapped the front Springs and replaced all four shocks. People say it's my frame but all the lines match up both cab and bed, some say leaf Springs. Need help please!
Sent from my SM-N920T using Tapatalk
weezman11
TX
Tommy
K5 BLAZER
My K5 leans to the driver's side. I've swapped out all the suspension components and gone through various rear spring packs (currently 6 leaf 56" springs with a shackle flip). New shocks, etc.. I have noticed the lean is less noticeable when the gas tank is closer to empty. No sway bar either as I'm running crossover steering.
JoshinIT
