Tran..
Natefew
Conroe
Nathan
V10 chevy
I put a chevy 454 in my 87 v10 chevy. And the convrter bolt holes wont line up with the flywheel wat can i do..
Jarhead79
Mt Vernon il
Michael
I would assume you may have to change torque converters or maybe there is an adapter? Haven't messed with this stuff and still learning. I know with an Ls motor I can use my 350th with it by using an adapter and modifying the bolt holes in the flex plate. Might be the same thing for the 454?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
What year is the 454 out of? What transmission do you have?
bigcountryguy19
Sealy texas
josh
6.2 diesel
Make shure you have a dual bolt pattern flex plate.
rollinon35s
wooster, oh
todd
If 3 of them line up bolt it up and forget about the other 3. That's what I was told by tech support at Jeggs when I called in with this question. But mine was a old 350 going to a newer 4L80 so I'm not sure if your issue is the same or if your bolt pattern is truly different.
Most apps only had 3 bolts anyway. Some of the heavier duty applications used 6 bolts.
I always thought there was only two mounting patters- a large and a small. But more recently I tried to use a flexplate from a vortec 350 on a tbi 350 with a th350 and high stall aftermarket convertor, the patterns didn't match. Had to use the flexplate from the tbi motor. So apparently some newer applications use a different bolt pattern than in the past.
spartantx117
