To clean or not to clean injectors?
347strokin
Vancouver Island
Jon
R15
Well...I'm getting really close to firing up this LS3! :893karatesmiley-thu
I've read in more than one place to have the injectors cleaned out before even attempting to start your motor if it's been sitting for any length of time. Mine hasn't run for at least a year that I know of.
What do you guys think? Just give er or what? Lol
Also, is there anything else I should do before my first start on this used motor?
Thanks!
Camar068
10 yrs Air Force
I'd clean them. Plenty of video's on youtube. If you have any go bad, you might look at getting the larger ones off ebay. Dougbert found some for $60 for the set which is a steal. Link below. If you use the larger injectors, you'll need to change to tune to reflect that.
http://www.ebay.com/itm/SET-OF-8-OE...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Did you pressure fill the oil? There's plenty of link on youtube for that as well. Basically you pressurize a container that has oil in it, and put it into the port on the drivers side of the block. I haven't done it yet, but apparently it pushes oil through all the passages.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I agree. Clean 'em. In the TBI world, people send them to WitchHunter. They clean and flow test, which is good to know that they're doing right, and you more than likely save the injectors and $$$.
If most of the LS swapping guys are making the suggestion and they all agree, then I think I'd do it. There's probably something to it or they wouldn't suggest it. JMO
Afterall, if you read it on the internet then you know it's true. :shrug:
347strokin
Vancouver Island
Jon
R15
http://www.ebay.com/itm/SET-OF-8-OEM-NEW-Delphi-Fuel-Injector-6-0L-GM-12613412/132202083540?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Wicked, thanks for the detailed info and the link!
347strokin
Vancouver Island
Jon
R15
Appreciate the info! Thanks.
347strokin
Vancouver Island
Jon
R15
Agreed.
yevgenievich
Viktor
sad
very sad
less sad
At lest cycle them nanually as they tend to stick
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I disagree. I picked my last LS up off the ground at the junkyard on 1/2 off day, opened it, looked around, reused every single bolt and gasket and put it in and did burnouts.
I've never cleaned an injector in my life, and have never stuck a stock one. I tend to keep thing's as simple as possible.
yevgenievich
Viktor
sad
very sad
less sad
It worked out for you, but on two ls swaps in my case I had a couple of stuck injectors. And also on a 7.4 vortec. It is worth checking. They might just unstick after idling for a bit or they might not.
74 Shortbed
Dale Downes
