That's really good to know. I was not aware of that. I usually have to look at a dimensions chart. So Th400/NP208 = 700r4/NP208 length, and the outputs on the transfer case should be the same too. Awesome.
Actually the th400, sm465, th350 and 700r4/208 all have the same length from block to tail shaft. The adapter is different lengths for all combos to make that happen.
At the same 65.8 mph you're currently running at 2500 rpm's you would be turning 1750 rpm's with the 700r4.
