TH400 2WD to 4WD Question
Kilian
Wisconsin
K
C2500 on its way to a K2500
Hello. Gathering some information for a possible 4x4 frame swap.
What needs to be done or even can be done to convert a TH400 from a 2WD truck to work with an NP208 transfer case?
My current tranny is good and would like to continue to use it if I go to 4x4 frame. Is finding a donor TH400/NP208 combo enough to get the transmission adapter, etc., to make it all work? Or is there a lot of disassembly required to the transmission needed?
Thanks for the help.
climb-101
montana
seth
c2 crew cab
6.0 LS
IF I remember right the th400 has a long shaft for the 4wd one and a short shaft for the 2wd. they interchage but the trany need to be pulled apart to change them out.
nvrenuf
Mobile, Al.
To run the 208 on the th400 output (bolt-on yoke, correct?) you would need a custom spacer to fit between the trans and the t-case adapter.
Justalex
Victorville
Alejandro
GMC jimmy
I was thinking of doing the same thing. But my turbo400 came with the Doug Nash (crash) overdrive. Does anyone know if they used a different tail shaft to tie into that overdrive system?
That's interesting. I had no idea there was a Doug Nash overdrive that fit the th400. Is it electronically activated?
CORVAIRWILD
Uppa US
UGLYTRUK
K2500 Suburban 4x4
My friend has an 87 K10 with a th400 np208. 5.0 tbi The truck has about a hundred thousand miles, and is rotted to hell, but he drives it daily. It replaced an even lower mileage 87 2 wheel drive, also 5.0 th400. And far more rotted than the plow truck, which is rotted to hell!
CORVAIRWILD
Uppa US
UGLYTRUK
K2500 Suburban 4x4
Maybe I'll post some pictures of both trucks, and even make a YouTube video for you guys to salivate over what the coronavirus can do to a Body and Frame
Justalex
Victorville
Alejandro
GMC jimmy
Yes it was.
Rickf
Grafton NH
1974, 1954 & a 1937
i can't think of any automatic where the output shaft is not the first thing down the assembly line. I could be wrong, I'm old. What about a divorced transfer case?
:cheers:
As was said, if it's the usual truck issue 2wd th400 with a bolt-on yoke, then a pre-'85 (figure 8 style) np205 will bolt right on. To run an np208 or np241, you can have a spacer made like @Honky Kong jr did, or the output shaft in the trans would need swapped out.
Side note, I don't know why there's not a company making a th400 type spacer like they do for the th350/700r4. If he weren't so busy already, I bet @Vbb199 could whip some up and sell a lot of them.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Obviously always remember divorced cases either yoke to yoke or with a jack shaft are an option too
Garcjay
