swapping in a standard trans?
87R10
Ontario, Canada
Scott
R10
So I'd love to swap my auto for a standard trans. I cannot locate any C/k's that have the parts I need. Man, these trucks are getting scarce, parts trucks even more so
Is there any other GM vehicles that can cough up a pedal set or one that might work? Does anyone know if a set from a Camaro or Iraqi-taxi will work? How much higher is the hump on a standard truck than the low hump tunnel?
I don't want to finish my interior if I have to mod the hump etc.
boneheaddoctor
Northern Virginia
Lester
Bumping this up since I've been looking too and not finding ANYTHING out there. Or much info of what else could be made to work. NV4500 swap is cheaper than a 4L80 swap...though I can live with the TH400 if I must. 4.10 gears and 32" tires makes for lousy highway driving when you are getting run over at 65 or 70 and that's winding the 6.2 diesel engine up way too high to suit me as it is.
JRandle
Verden, OK
Chevrolet Silverado
Bump. This idea also has me pondering about the nv4500 swap from my current 700r4.. Hmm.
marks86
Latham, NY
Mark
12v Cummins
I just got done with my nv4500 swap. I love it
marks86
Latham, NY
Mark
12v Cummins
Did you have an automatic before?
yes I had a turbo 400, I truly wanted to put an Allison in but that's really expensive stuff
First you need to decide if you're going with a manual Z bar clutch linkage system or a Hydro system using a master and slave cylinder.
Once you know which set of clutch pedals you need, post a Wanted ad.
@RetroC10Sport seems to be able to source clutch pedals from time to time. Get with him and find out if he has a set or get on his waiting list of parts.
JRandle
Verden, OK
Chevrolet Silverado
Which would be a better clutch for my truck when it's ls swapped/daily driven?
marks86
Latham, NY
Mark
12v Cummins
hydraulic is newer and more reliable.. some would disagree but new vehicles use hydraulics for a reason
JRandle
Verden, OK
Chevrolet Silverado
Makes sense. I guess I just need to figure out prices on both of em..
Sherrow74
Missouri
Cole
Can you run an np203 with an nv4500
Rule_So_Hard
Northern IL
Richard
k5
While this is 100% true my personal beef is that they feel sloppy. Look at performance machines that rely on clutch feel and performance such as dirt bikes, they always run mechanical clutches.
It is also populer in many motorcycles to swap out for a mechanical clutch.
But these are applications that that particular setup accels in. In everyday driving the hydraulic clutch has less moving parts and IMO is easier to install.
If you've ever drag raced a manual transmission, you'll KNOW that Z bar manual linkage is the way to go. When I drove a couple other race cars for buddies that were also Muncie 4 speeds with Hurst Competition shifters, which is what my truck had, but with a Z bar set up, I was able to float the clutch and actually spit the slave cylinder piston out the slave cylinder. Especially on a close ratio trans with a low gear ratio rear end. The clutch hasn't even completely returned home before you're trying to get another gear, therefore you've lost the race. Of course that is some side stepping and some FAST shifting to do that, but it can be done.
That being said, past drag racing, the hydro is better for several reasons. I was looing for Z bar linkage clutch for my K10/20 build. Some good valid points were made about the hydro, and yes, I did certainly change my mind. When it comes to lift kits, the linkage is going to be a problem where as with hydro, a longer line from the master to the slave and problem is solved. Also routing for off-road headers was a reason, and the biggest thing that convinced me to go hydro in a 4x4, is frame flex. If you're in a reveen or over a rock and need your clutch, the frame is likley to be twisted and that will throw the geometry of the Z bar linkage off big time being that the Z bar is supported and pivots off the frame and the engine block. So for a 4x4, consider hydro as your only option.
aaron06
