- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
I installed a factory 3rd seat in my '88 that did not come with one, I thought the install was pretty easy. I just got a seat and seatbelts from one junkyard, had another junkyard cut out a set of mounts for me, then did a little cutting and drilling.
I positioned the seat on the floor and marked where the front mounts needed to be. I trimmed the donor floor mounts a bit so they had a healthy flange around the perimeter, then cut openings in the floor so the mount pockets could sit flush in the floor. Rather than welding them in (due to the fuel tank), I mounted them with 12 or so 1/4 inch rivets on each mount. I feel it is just as secure as welding. Then with the seat slid into the front mounts, I marked where the rear mounts needed to be and then mounted them just like the other pair.
The seatbelts were easy because they were just lap belts. Just drill holes and bolt them in, with a very large washer on the underside of the floor.
Then enjoy having a 3rd seat.
