77chevy400
- Mar 8, 2015
- Eastern NC
- Chris
- c10
- 6.6l (400)
I heard some popping coming from exhaust which indicated to me the carb wasnt adjusted well while im looking at the carb i couldnt tell which screw was for air and which one was for fuel.
I believe i figured out the one below the fuel filter is for fuel and the one on the right side for air.
I found out by turning air down till it barely ran. I turnt the fuel down till it just simply bogged out.
Tuned my carb and wallah. Runs way better now. Feels better driving it aswell.
I do not know if i have a vacuum or double pump carb. Seems to me like the rod that connects the pedal to throttle butterfly for the four barrell is missing.
I have 3 holes on my carb thats midding vacuum lines or there capped off(will be getting a chitlons or haynes manual tomorrow to fix that up).
I have no windshield fluid resevior? Where is it suppose to be located.. I have this huge clip bracket on drivers inside fender. I was thinking maybe there.
And also how do u adjust timing. I always heard u turnt the distributor. Well i tried and it wont budge. Is there a bolt or bracket holding it down?
Sent from my Reddot R50 using Tapatalk
