Stock radio won't work
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
Goodwrench 350 5.7 L
So my radio won't work in my truck? I have another one from my k10 that I can install in my k30 easily could it be wiring or is there known problems with the radio or what? I need to get it workin! Thanks
chengny
If the fuse is good, check for power on the yellow lead in the power harness connector (the one with the yellow, gray and black leads). If you have power there, check the black lead for continuity to ground.
If you have power on the yellow and continuity to ground on the black...put your other one in. Matter of fact, it might be easier to just do that first. If the other one works...the installed unit is bad.
You do have a set of speakers hooked up correct?
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
As far as I know yes the speakers are hooked up I think
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
Where is the fuse and is it a tube or a little color fuse
chengny
The image below shows the location of the radio fuse. It is a 15 amp ATC type fuse (i.e. the two bladed stab-in style). The use of glass tube fuses (AGC type) was phased out universally in 1981 - and US manufacturers had switched to ATC fuses even before that.
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
Ok so I changed 1 speaker and then tried the radio and it worked like should! Then I ate lunch and started the truck up and it didn't play but me and my bro can here it work like turn on but it is super hard to get a station, i dont know i think it needs a antenna or something
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
LFR
Boyne city Michigan
Lorin
Custom deluxe K30
Hey guys I haven't fixed the problem just yet! :) does anyone know what the problem is with why sometime you hear it's on but there is no fuzz so it won't pick up nothing?
soliddrummer
