Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
Yes negative arch three leaf packs on a CUCV
Stock 1-1/4ton CUCV springs will not ride great no matter what...unless you plan on running around with an ambulance body on it. In other words, they’re probably not worth hunting down. You should look at your average load and go from there.Just trying to lower the truck so I don't have to climb into the engine bay to finish up the wiring and engine swap. When I'm happy that's all squared away I will look into a small lift. I'd like to keep the towing/hauling capacity high. Do the stock springs have better ride quality under load?
