Stereo install from new to oem
Bigjake
Lake lure, nc
GMC Sierra 1500
350 v8
My 87 stereo hole has been cut to fit a new style head unit. Is there any way to return an OEM without replacing the. BEZEL? Also, where do you find the new head units made to look OEM? I want the original style with the upgrades of new, digital, USB port etc... t.i.a.
WebMonkey
Missouri Ozarks
you can get the installation kit for the squarebodies.
it is a kit for putting a din mount in squarebody.
the face plate it comes with, however, has the traditional 2 shaft style layout.
(you can also 'knock out' that layout for a full din)
so you get a 2 shaft, din mount radio that will look original style without welding in a replacement panel.
otherwise, you'll need to weld in a panel.
the shaft mounts are recessed and that is what 'holds' the radio in place for the most part.
i went the adapter route myself to fix a butchered panel.
good luck
Rob Goblin
Fayetteville, Arkansas
Rob
good luck
WM you got pics of it installed? I’m about to cut the dash on my lwb to weld in my swb, but if I don’t have to do it...
Craig 85
Nashville, TN
454/TH-400/NP205
WebMonkey
Missouri Ozarks
i used the same 'kit' as Craig 85 (whose truck is MUCH nicer!)
my truck came to me with the dash cut out and oversize at that.
i think my son said there was a full size CB in the opening.
i welded in some metal and smeared some filler
i bought a chinamart $20.00 sd card playing fm tuner stereo
it'll do for now.
good luck!
RoryH19
Rory
R10 Silverado SWB
it'll do for now.
good luck!
How did you support the back of the radio? Did you use the factory metal strap?
Also, I have the same plasic face behind your radio. How did you get the radio to hold itself in place?
Mine is trying to slide out.
WebMonkey
Missouri Ozarks
the radio is a cheapie and super light/short (no high power mosfets/heatsinks) so i didn't use the 'plumber's tape' strapping in the back.
the radio slides into a cage.
the cage has tabs all around the perimeter that you bend up to lock it into the mounted portion.
the radio then slides in and snaps into the cage.
2 popsicle stick looking things insert on either side to release the radio catches if you have to remove it again.
good luck!
RoryH19
Rory
R10 Silverado SWB
good luck!
Thanks.
yes I have a pioneer radio with a built in amp and other features. I'll have to use the strap or it pitches up.
I need to adjust my tabs to hold better too.
JOD26
