Squarebody Down! HELP - Member Roadside Assistance Volunteer Map
Anyone in Northern AZ or Southern NV depending on where he actually is, mtnmankey aka Kevin is in a bind and can use some help getting some rear brake drums off of a 14b SF rear axle.
is their a way we could ad contact info and keep it semi private.
only members of this site have access to it
It's the internet where ALL things are private
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
That's the best joke I have heard in a long time.
Thanks for making me snicker.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Brake drum is off !!
I had forgotten an old trick that sometimes works, tapping on the drum between the studs with a hammer.
It took a herd of taps, but I finally heard the sound change that told me the drum wasn't glued on any more and would come off.
Only way to do that is move it to a members only section in here. This is not a public view map per say, only those who can find the link posted and click on it can see it. That is why I did not choose to embed the actual map into the first post. There is no way to password protect the map itself.
All you are donating is your zip code so it's not showing your house. Or pick a zip code or 2 away to use if you are worried about privacy.
Good job. Heat helps too, like a small propane torch to heat that area up you were hitting.
There you go. The WD-40, or Release soak whatever you chose to use, and the light tapping will usually get it done. That sound change was when the rust finally let go. What can help that in the future, last thing you do before you put the drum back on to finish up the job, put some white lithum grease or some vaseline on the face of the axle around all the wheel studs and around the centering lip where the drum touches the axle. In hopes when the drum needs to come off again in 5-7 years, it will release easier.
I don't think anyone is worried about their zip code. I think what he's referring to is, members names or phone #'s to be able to call someone up directly in that area.
Hey 89S :wave: Did you get off work early today??? How did you get to get online this time of day without Tapashit?
Seems to be unblocked again at work right now, and I finally am getting caught up and getting some play time here and there all of a sudden. We'll see how long that lasts.
Carb'ed Vortec 350
I need to add mine...93302
sonicbluezx3
North Carolina
Steven
You can add me to the list as well. Looks like I'm pretty close to offroad-cowboy. I'm down in Gastonia near the SC border.... 28056. Got plenty of room in my garage to work on something if needed, have a decent amount of tools as well.
Done
Carb'ed Vortec 350
Could you add me?:popcorn:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
25301
Tow bar, hand tools, air tools, welder, cherry picker, jack & jack stands, very precious few spare parts, beer.
We will probably have to **** with the tow bar to make it work though, haven't had to use it yet.
1998_K1500_Sub
