spring perch lift
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
you could use a 4x4 shackle but i would cut off the top and drill out the rivits and just use the 4 bottom holes to bolt it to the frame
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
The shackles are off a chevy 1 ton crewcab and i measured and from bolt to bolt they are 6 inches.
Your tape measure is broken, or it's not A stock shackle.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
my crew cab shackles are 4'' its a 1 ton
sean1960
Wylie Texas
Sean
Custom GMC
Two wheel drive spring hanger I used on the rear of my truck.
chevydude
arizona
hunt
k20
What doese using a 2 wheel drive bracket do to help
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
the 2 wheel drive bracket is shorter and does not hang as low as a 4x4 mount
if you want more lift cut your front hangers off and space them down 2' or so with a peice of square tube then redrill the mounting holes
then use 2 wheel drive brackets on the rear for the shackle flip
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Not the ideal way to do things, as the tube can crush under side loads. A simple angle bracket with beefy gussets would work better.
joseph916
