SM465 4 speed vs other options
777mech
Stanwood, WA
Trying to decide which transmission to go with when I put my truck back together. It's a 2wd shortbox that came with a sm465 4 speed. The few years I drove it the rear end was geared at 3.73 and it seemed alittle low for freeway speeds. Do any of you have a 465 in your 2wd truck and drive it alot on the highway? If so what are you running for rearend gearing? People keep suggesting to put an auto in it but I have always perferred manual over auto. My intentions for the truck are to lower It and mainly use it for cruising around and going on the occasional long trip down the freeway. Should I stick with the 465 or is it silly to use it for my street truck that never go off-road or tow anything super heavy? The motor I use will most likely be a 383.
Westislander
Massachusetts
Gregg
NP833 - 4 speed with overdrive, very similar to the Legendary Mopar A833
hatzie
k20
The SM465 with a Gear Vendors Overdrive has the same gear ratios as an NV4500 with a lot less headache. You can split gears and tow in Overdrive too.
nathanjohnson85
