Show me your 8 lug wheels!
83chummins
Chico CA
Marc
sierra
91.5 5.9 12valve
Yep that’s the size I have. I have all 4 that size out back. I did have to put a 2”
spacer in to keep them from rubbing tho. Everything clears on my stock one ton. They run the drag link a little tiny bit at full lock but that’s it.
That is a hell of a nice truck!!!!
Sent from my QTASUN1 using Tapatalk
r67northern
Louisiana
Leland
Suburban r20
Thanks guys - I found those caps over on ebay a while back, they've grown on me. I replaced the sagging rear springs with HD springs, that reset its ride height, I think it's come together well.
87silveradok20
Ohio
Levi
Silverado k20
Thank you! The other side isn’t as pretty( it has a mismatched door and the paint falling off) but it’s coming together quite nicely.
r67northern
Louisiana
Leland
Suburban r20
Agreed- coming together very nicely.
carlgm
Fl
Karl
'85
Got these on my sons truck
8 lug 10x15
Nice truck! Any info about the suspension/lift?
roundhouse
atlanta ga
justin
77,78,79,80 ?
Think it’s a 4” lift
We pulled the axles and springs off a parts truck
After we broke two 10 bolts , we bought a parts truck for the 14 bolt axle and a few other parts
It rides rough , I know that .
And hardly anyone makes 15” tires anymore
rpcraft
Robert
LS 6.0 364 CID
The 16.5's used to be very common. But those 15's have got to be super duper rare.
I think it was opposite. 15's 5 lugs were very common from what i recall on many cars and trucks.
I meant as far as the 8-lug mag wheels go. 15's are nearly non-existent.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Picked these up recently from another member. Stock 17" H2 Hummer wheels with the centers bored out.
rpcraft
Robert
LS 6.0 364 CID
I wasn't aware you had to have the centers bored out on those hummer wheels. Thought they already fit for whatever reason. is it just the front axle that needs boring or both axles?
87R10_Cruising
