seat swapping?!
dirtroadoutlaw
Florence, MS
k5
Mine must be '03.... hmmm....
Sent from my SCH-I500 using Tapatalk 2
Unpredictable1
AB
LB
Sierra Classic 1500
so you were able to just put the seat on the original track in your truck? im looking to do the same thing in my 87
I'm wondering the same thing - I'll do this mod this week if that's the case!
well mine sit about 1 inch higher that the bench and they go back far enough for me im 6'2" i have plenty of room..now Old77 did his by lowering the floor so his sit lower than mine do. and in the blazer they sit just about the same as the stock seats do. The only thing with putting them in a Blazer is they dont lean forward as far as the stock seat do so a lil bit harder to get in the back.
Old77 chim in any time man
Just now saw this....I'm a doofus.
The column in my truck is not a tilt column so it partly necessitated the way we did it or the seats would have been TOUCHING the bottom of the steering wheel which obviously wouldn't work for us :lol: if a tilt column is present I can see where the way 78shortandwide did it would work. I also like how mine came out because they sit flush against the floor and fit "like a glove" in there.
EDIT: the link for my seat mod is linked in my sig.
lowblackc10
central NY
jerry
305/th350 now - 350/m21 soon
I actually swapped out my bench for the buckets, console and floor shifter from a 79 cutlass. They sit a bit lower than the bench but they are much more comfortable and I like the way it seems to match the rest of the interior.
John81287
Mchenry,IL
V20
Mine required floor to be cut on my V20 I don't have any pics as my conversion is not yet complete. Hopefully be done this upcoming week. The problem I had with my truck is the hump in the floor for the fuel tank sat too high and my head was about and inch from the roof. Not real comfortable.
woodchuck
Enosburg VT
Jesse
I know this is over 2 years old, but 78shortandwide what mods did you do to your stock seat bracket to make the seats fit?
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Got any pics? Did you have to fab some brackets?
75Beast
California
if anyone has the hardware for a bench seat I'm looking to purchase
Brocketfire
Washburn, ND
Brock
5.7~350
HEY All a Seat question
Would bench seats from an 80' be a direct fit to my 81' im tearing down my 80 and the seats were in great shape would like to swap them over if it does easily enough if not i will just get some from a newer truck and fab the brackets up. Thanks all
87silveradok20
Ohio
Levi
Silverado k20
put some pics up once you get done i am looking into swapping mine too
87silveradok20
Ohio
Levi
Silverado k20
They probably would just measure the mounts to be sure.
79K10
Sacramento,ca
Ryan
350/th350
i just traded an edelbrock intake for these, im not sure what year they are from but im sure im gonna have to modify something to make em fit
firebane
Calgary, AB
Curtis
95-98 GMT400 trucks. Fairly common swap.
79K10
Sacramento,ca
Ryan
350/th350
ive been checking out all the threads on seat swaps... i liked the one where he cut the floor and welded on sheet metal, but i dont have a welder... is maybe finding donor brackets from the pick and pull my best bet?
firebane
Calgary, AB
Curtis
For my 74 I got bench seat brackets from a 79 so I could put in my buckets.
strokedK15
