- Oct 27, 2016
- MO
- Spencer
- 1971, 1̶9̶7̶4, 1976, 1979,1̶9̶8̶5, 2002
- Dart Swinger, Sierra 10, C10 Cheyenne, C10 Big Ten, Silverado 10, Ram 2500
- 225/6, 350 c.i., 350 c.i., 5.9l Cummins
In order to continue the restoration of my 79 going, I'm going to get the frame soon to get a couple parts off of it and then arrange to have it dustless blasted, take it all apart and then get to rebuilding and painting everything. After that start putting it back together and get the cab mocked up on it to verify the location of the mounts still plays along with everything.
I have no reason to believe that worn out front end components were the reason (or part of the reason) why the truck got parked, I know for certain now that the trans was cooked and figure that was the main reason why. When I flat towed it it tracked great and didn't seem to have any death wobble. But being that everything has sat for so long with not being greased properly and just recently spending a few months underwater, I want to for the peace of mind replace all the front end components.
So with that said, I plan to replace/use:
-control arm bushings (already have energy suspension kit)
-ball joints
-tie rods
-idler arm
-pitman arm
-put solid tie rod end sleeves to replace the 3 piece design
-Borgeson steering shaft (to eliminate ragjoint)
-Wheel bearings & seals
-Front coils (will keep HD rating coils)
-brake proportioning valve
I have heard good and bad things about most brands for these types of components, so I'd like some input on what others have used and how it has held up, I have no issue with spending a little more for quality components. Truck is a 6200lb GVWR Big Ten and I plan to take advantage of its GVWR so I'd like to retain heavy duty components where possible.
-ball joints
-tie rods
-idler arm
-pitman arm
