- Sep 29, 2010
- Green Bastard Parts Unknown
- Jay
- pontiac aztek
[yt]N5a2Eli6M8w[/yt]
Is there an EGR setup on this?
Double check the intake tubing as it was wrapped with electrical tape at one joint before. I had to replace some spark plug wires on it, never had it long enough to put one new set on. I had somewhat new spark plug wires fail before, it is worth double checking as it does not look like they are tied off very well. I can also send you out another relatively new iac if you want to try another one. And tps as well.
The valve it self in the transmission might be sticking after a fluid flush if new cable does not help.
