Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
Greetings. Is the rear hatch dome lamp switch adjustable on my sons 92 Yukon? Occasionally the dome lamp will stay on. Push on the rear window ever so slightly, the lamp will go out. The light will flicker when driving over bumpy roads. In a moment of sheer brilliance (otherwise known as McGuyverism) I put a rubber vacuum cap over the switch plunger. That fixed the problem. Unfortunately, the rubber vacuum caps don’t last long. But that temporarily solved the issue, so the switch adjustment is definitely the problem I just need a more permanent solution.
