Project Mini me
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I figured I may as well start a mini build thread on this one too.... This is kinda a continuation of my other project in under construction " project F smog" which is probably a few pages back by now.
For those not familiar, Basically i was building a 2wd c20 into a 4x4 k20 in my driveway, someone called the city, so had to move the vehicle inside my garage via a friendly neighbor using his f250 to push it in. No steering and a locked up axle made it a real hassle.... Also pulling it in and out to continue the build his really not an option by myself.
So I bought this little thing like a week later... asked $2200, low balled $1400 and got it for $1700. Compared to some other test drives, she Drove great, and had immaculate engine bay, so snatched it up. Was fine until a week or so later when the check engine light came on, when I realized he did the individual check engine clearout. So I took her to AutoZone to read what the problem is...
Now I have a decent tool collection, but I can't get to them with the k20 in the way, so had to use their code reader which produced 3 codes p0420, catalytic bank one efficiency low, something about pirge threshold low, and another on which I think the new gas cap fixed.
I spent $ on a smh diagnostic and basically had $300 tune up done. I still have a steering rack leak, and need a new cat... but she runs great. Paid registration, but need smog (go figure) smh
The goal of this is to make a mobile crane to bullbar the k20 in and out, and also use a front winch.
Here's the pictures to catch you up...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I knew I needed to get this tracker higher so it could push the k20 and needed some altitude to Align the trackers push bumper to the k20 rear bumper.
Started checking out comparable wheels....
Scouted these out on CL for better backspacing...
Teaser
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Here's the engine bay... 4cyl 2.0 auto...so she has 260,*** but supposedly brother of previous owner had replaced the engine 100k ago. But after the check engine okiedoke, may not be a reliable historian. Runs great though and Compression 185 across all cylinders. Engine looks showroom clean up top.
Going to have to go in here and get this cat...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Got the 4 x heat shield bolts out 8 or 10 mm had to use wrench
Here is the upper cat
3x14mm bolts off...Gunna put in two o2 sensors while I'm here because I will have to smog again in August..
About halfway through I had to stop as the old cats bolts were welded on for easier install, and i needed three new bolts , going to splice o2 wiring as well so needed electrical tape
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I had trimmed the front bumper cover for clearance a few days ago....
I broke down and bought a tool set for basic wrenching and when I can get to my other tools, it will be for pick n pull trips....
I got a new jack too because I broke the last one getting the k20 in the garage....
URL=http://s219.photobucket.com/user/rawbulks/media/Mobile%20Uploads/IMG_20170113_194731.jpg.html]
[/URL]
Ultimate plan is for a bumper like this..... I see their better business bureau ratings, but they're in Bakersfield CA so if there's one in stock I can pick up, I may consider them....
But she looks better already.....
The rain has been pouring in CA which is great for the drought, but slowed progress....they said 14ft of snow in the last eight daysup the mountains....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I also ordered a 2" low range off road suspension/ spacer lift, 2" body lift, and rocky road steering shaft spacer for body lift -but may or may not need it... gunna try with my now limited hand tools-when I have a McPherson strut compressor in the garage.
At least I'm back to enjoying wrenching again. Got the excitement....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I got the catalytic converter and o2 sensors in, just need to splice the o2 sensors wires.
Saw a few issues....
One is my oil dipstick is not seated in properly....
Two is it appears as if this is too oily and maybe leaking, looks like an oil pressure sensor in the block.....but it could be coming from above and dripping down onto this too....
Three is a PS rack leak....
But after I remedy all this, and hopefully with fluid changes, she will be sorted out...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Had been researching gearing for the bigger tires... apparently the low gears are under rare and unobtainium. looks like a 99 5.12/5.13 will have to do... I would have loved the 5.375s and 32x 9.5 x15s but oh well. I hope to get a whole diff front and rear to swap. Stock size is 29x6.5x15 @4.88 gears equals roughly 3674 rpm.
A side by side of the bfg at vs stock
I saw this and didn't have a matching spare so picked it up yesterday.... he said from a 72 Ford...
Had to take off the rear bumper cover so it could fit, but I planned on taking it off anyway...
Still gotta trim and put on the 2" suspension and 2" body lift so I can get the tires on...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Oh I forgot, it's been so slow as after years of CA drought I have only got a day or two in on this since last post. She passed smog, but dmv hasn't gotten it yet, so I may have to go down there. I also have to smog again in August since it's tagged for that month. I have had trucks that wouldn't pass smog once lifted, geared, tires , so want to be able to leave it till after August.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
One last chart
Just wanted to cite some references when I was searching for hours on the web of some pictures of other guys builds I will incorporate into mine...
Overall I intend to build like a four door version of this....
But I like how this guy relocated his turn signals into the fender (where as the guy above just deleted them)
And if I need more clearance, I can do like this, but since I bought a low range "kit", I don't want to piece it together just yet.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Got some plastics removed, and turn signals relocated...
Teaser
Still gotta install the lift and trimming but it was her in what I could with sprinkled showers today.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I found a deal for $240 for this bumper which is much less that the $675 cal mini wanted. It would likely take some fab to work, but once the body lift and gap are there may clean it up. I haven't pulled the trigger yet, but the width seems do able.
But I still want to trim the rear quarter panel near the bumper as flush as I can...
Hopefully I can sneak some hours in before work if it isn't nasty weather out. Little by little.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Got about two hours of trimming in with the angle grinder.
Stock
Rear bumper cover removed.
Trimmed the outside..
Then inside...
And ended up with....
. Couldn't get the passenger side all the way, but will hope to this week.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
In the last post of the passenger side this was supposed to be the first picture of trimming the closest surface to me....
I had started trimming the driver side rear, but found some things tucked up in the quarter panel...
I know the tubing is just for water drip from jams, but need to investigate the other stufff. Haven't really been up under one of these things. Might be diff breather or charcoal canister type thing. Ran out of time before work.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So the pieces inside the wheel well turned out to be the spare jack and jack handle location, and the diff breather I still have to deal with.
Stock passenger rear
Stock driver rear post trimming
The clutter is real..
Got the rear low range off road 2" spacer suspension lift in and pro comp shocks....Plus the 32/11.5/15 bfg ATs
Some of the pics mist not have made it thru Photobucket, like the pics with the spacers and shocks installed and wheels removed, so I'll post em when I can. Try the front tomorrow..
mick84
