Posi-limited slip-tru trac!
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
Posi-limited slip-tru trac! what is my best option to convert my open carrier from my 1986 10 bolts 8.5 30 spline?
use, what can fit there? all 8.5 30 spline are the same? got GU6 3:42 gear that i want to keep! thx for your help! :)
84c10Tony
Howdy!
In, but not from So Cal
Tony
Was 84
01 Sienna
Years ago, had an Eaton Detroit Tru-Trac installed, all new bearings and one new axle, by Robert Thomas in Hesperia, CA...really good stuff. All gears...No posi lube required.
78C10BigTen
pennsylvannia
C10 BIG TEN
I just put an eaton clutch type posi in my 10 bolt 3:42 30 spline rear earlier in the year. So far so good. I should correct myself... i swapped my 12 bolt to a 10 bolt and swapped in my 30 splines and brake setup with the aftermarket posi.
ali_c20
Austria
Alexander
C20, K5
I also have the eaton clutch type posi in my 12bolt rear end. Works as it should and chirps the tires when going around tight corners. I only drive streets , dirt road and very mild offroad. For hard offroad use I would recommend something different.
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
that my dilema....do i have 30 or 28 spline? only way to know is to open my diff!? lucky me i found a place not fare from me ...they have both in stock Yukon duragrip (30 and 28 spline) cheaper thant the one i can buy on the web so i'm gonna grab one of my axel and get there! ;)
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
'86 should be 28-spline. I think the 30-spline started in '89. IIRC. Some say late '88 model could have the 30's but mainly '89. I'm sure someone will correct me if I'm wrong.
78C10BigTen
pennsylvannia
C10 BIG TEN
My posi unit was only 300. I bought the 10 bolt rear and put my 30 splines and brakes and posi in but left the 3:42 gears
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
confirm 28 splines and now ready to go Yukon gear LSD! :) one axel shaft was worn out so i found a new one! :)
If the rear end is in good shape, works as it should and not whining, then you might consider a lunchbox locker if it's fairly stock. The advantage to a lunchbox locker is you don't have to reset up your gear lash and all of that good stuff. Lunchbox locker is pretty much just a spider gear replacement directly into that same open carrier. PowerTraxx by Richmond Gear makes one called Lock Right, Yukon also makes one. Do keep in mind though, it's a Locker so both wheels are locked up at all times until you turn a corner and one axle has to break free from the locker so it can make a bit of noise. The Posi or Limited slip unit is always a one wheel peg legger until slip is detected, then it'll grab the other axle to help propel the truck. Pros and Cons to both systems.
Josh Helm
Mooers New York
josh
K1500
5.7 vortec
I have a true Trac in mine and love it ... and as the other guys stated ... nofriction modifier or clutchs to go bad ... I am had on my truck and it's always posi ... but the 1-.5 ration allows for cornering with out chirping ... unless the skinny peddle is used then it's sideways... mines in a 8.5 with 28s at a 3.08 ratio gears for days... want to swap to 3.73s for better crawling
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
thx guys the yukon duragrip will fine for me at a decent price! :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
old spider was shot so it was about time to change it anyway! :)
71RAT
Deerfield NH
Kirk
K20 Scottsdale
I'm partial to the clutching units, Eaton and similar. That being said the Tru Trac looks to be well made and seems very strong. I've installed an sload of them over the last several years wiyh no problems. The lockers I'd stay away from, on a street driver. I have a Detroit Locker in my truck, not a big fan until your in a situation off road.
78C10BigTen
pennsylvannia
C10 BIG TEN
Not as shot as mine! Lol wich was the whole reason i put the posi in mine
3dbello
