Popping noise heard & felt when in hard right turn from standing stop
davetyp
High Springs, FL
Dave
Begging some input from the group. Have an 83 K20 305 SM465 NP205 4.10 14bsf rear (not posi) & 10b front. While in 2 HI if I have the steering hard right (not quite to the lock, but almost) and accelerate briskly from a standing stop, I hear and feel a single loud body/suspension/driveline/something pop. Feels stronger than and is louder than a posi pop (this rear isn't posi anyway). Do not feel it in the steering wheel, but more in the seat of the pants and the shifter handle. Does not do it when accelerating gently or when not turned hard right. Checked the U-bolts on the rear springs & crossmember bolts. Nothing loose. Just did front brakes and found no wiggly ball joints, but just checked by wiggling the wheel & tire. Is there anything else to check? Or a better way to check the ball joints? Didn't bother looking at the U-joints because that popping sound never happens unless the steering is almost hard right -- but I'm not ruling them out. Any advice appreaciated. Thanks!
TX87R10
Patrick
No idea if it is similar to my issue but for me a rock got down between teh bed and the cab and couldnt' get loose. When I was turning it would pop loud as **** until I figured out what it was and scooped it out. Not saying you have the same issue but check behind the cab just to be sure.
davetyp
High Springs, FL
Dave
Great idea, thanks! I just checked, nothing there. :(
Pick the front end off of the ground (hubs unlocked) and check for a zerk fitting on the axle U-joints. It sounds like one of those could be culprit.
If they have a zerk you'll need a needle type to geet some axle grease in them. DO NOT USE CHASSIS GREASE!
Shorty81
Baby Boomer
North West ohio
Darren
Do you have a lifted steering arm? If not it will rub.
80BrownK10
Greenwood, SC
Nate
I use to have a bad clunk when I got on the gas hard in 4wd. It didn't have to be turned though. Mine ended up being soft collapsed transmission/t case mounts. New firm mounts didn't allow the drivetrain to torque over and front drive shaft to hit the cross member. Really don't think this is yours since you said steering has to be turned hard to make it do it. Which makes me think it's that outer axleshaft bearing.
Washington
This is a good suggestion and possibility. Is the lift newly installed?
It's not any u joints up front, as they are not even rotating if you're unlocked an in 2wd.
Anyway, great looking truck!
davetyp
High Springs, FL
Dave
This rig has a 4" lift and a raised steering arm; the drag link is horizontal (as it should be).
BUT
Now that you bring it up, the previous oner put rims and tires from a '90s model on this rig -- they're 17" aluminum rims and I'm wondering if the backspacing is wrong for this application. The inside of the left front tire will rub against the end of the pittman arm when cranked too far to the right. It could be that the "clunk" I hear is interference there. Oddly, I do not feel that clunk in the steering wheel. So maybe that's not it.
Been looking for different rims to eliminate that problem, but the choices for an 8x6.5 lug steel wheel are limited to say the least. I want a period correct steel wheel, 15" or 16", to mount some 34" or 35" tires. It's looking like wagon wheels or stock steelies are the only options.
Washington
@davetyp
Wheel Vintiques has classic painted or chrome OE looking steelies.
US wheel has several styles/colors of 8 lug steelies. As do some of the off road store websites.
Detroit Steel Wheels has several styles in about any rim size you could imagine. But they’re pretty spendy.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I've heard stories of cracked frames popping, worth while to check the frame near the steering box.
80BrownK10
Greenwood, SC
Nate
Yep how could we all overlook the classic cracked frame at the steering box issue.
dvdswan
Port Orchard, WA
Dave
Take a look at the suspension bolts for the leaf springs. Make sure they're not broken.
davetyp
High Springs, FL
Dave
White spokes look good on old Chevys.
Indeed they do! Always liked them second best. What would be way cool is if someone made rally wheels in an 8x6.5 pattern... but as far as I can tell, those are unobtanium.
Charkmapman
